1 - 4 of 4 Posts
Hi I urgently need to know where the sump plug is located under my megane 225 any help would be great
Please don't take this the wrong way but if you can't locate the sump plug then should you really be attempting to change the oil?
You will have to remove the under tray, then you should see it at the bottom of the sump and you will need an 8mm square plug to remove.
1 - 4 of 4 Posts
