1 - 7 of 7 Posts
im attempting an oil change on my 225, the bolts/screws which hold the undertray on just keep spinning any ideas?
you need a lot of force the captive nuts that are inbeded in the frame have come loose
One of mine is doing the same how do you stop it spinning don't completely understand what you mean mate?
I've had several of these, usually after winter when the road salt has rusted the backs of the thread. Had to drill the head off the bolt and remove the left thread with pliers, the two rear ones can have the inserts drilled out and new rivnuts put in.
The fronts are special so have either had a bit of weld or a decent metal epoxy to hold them. And coppergrease the bolts now.
1 - 7 of 7 Posts
