1 - 15 of 15 Posts
iv got a bad oil leak from the farside of the gearbox where the drive shaft connects.
the shaft seems ok but oil has leaked out from seal.
can i get a new seal or ?
surely cant need a new shaft?
The seal is part of the inner cv joint,its a metal seal.
Should be able to buy the inner cv
No it isn't, diff seals are interferance fit into the box casing. The cv only has the metal plate to sit against the seal. New seals are about £20 from renault but you obviously have to remove the shaft to fit and everything that comes with it.
Can anyone get me the part number so I can order the seal?
I can move the shaft easy I think once hub end bolts out the whole lot shaft included slides out with enough room for a seal?
Ok thanks will I need to remove shaft completely or can it just be slid out the way?
Remove the plate that holds it in place and undo hub carrier from bottom?
Might get a garage to do it.
1 - 15 of 15 Posts
