I have been looking into this, if you look at the picture below you can buy a temp sensor to fit straight into the sump plug. Then install a gauge run the signal from the sensor, supply +12v and a Ground (for the signal and the voltage) and voila!
not messed with the ECU or wiring so easy to move if needed
As far as pressure goes there is a sensor that will tell when the pressure drops too low and illuinate the 'check oil' lamp, but its not sufficient to provide a good enough signal for pressure i think. so you'd need to replace the sensor for a better pressure sensor. but its linked to the ECU(at a guess) so you'd have problems maybe, or tap into the oil gallery and put a seperate one in!(think i'll leave that one for now!)
temp sensor
pressure sensor
temp sensor
pressure sensor
