Hi guys I’m new the forum , just after some help and advice 🙏. So the issue I’m facing is under acceleration it hit 3000rpm and the car hits a wall and coughs splitter shudders ect then picks up to around 4000 then same again with a puff of black smoke 💨 . Driving normally through gears at low speed has little if no issues 🤔 , so I have read other posts and done the following so far - new fuel pump , checked All injectors and replaced faulty one ,fitted new spark plugs , fitted a new engine temp sensor ,full oil service coils are around 1 year old and covered 1000 miles . Any other suggestions as the the possible fix would be very helpful 🙏🙏
