Have you had an engine fail? What level of tune were you running?
  • Standard
    Votes: 1 14.3%
  • Stage 1 = mapped only
    Votes: 1 14.3%
  • Stage 1 + = mapped with FMIC
    Votes: 0 0.0%
  • Stage 2 = mapped with FMIC
    Votes: 3 42.9%
  • Stage 2 + =mapped with FMIC + de-cat
    Votes: 2 28.6%
  • Stage 3 = mapped with FMIC + decat + injectors
    Votes: 0 0.0%
  • Stage 3 + = mapped with hybrid turbo + FMIC + de-cat + injectors + fuel pump
    Votes: 0 0.0%
  • Stage 4 = Forged internals
    Votes: 0 0.0%
1 - 12 of 12 Posts
Please could any members with failed engines vote as per the options in the pole and also comment in the thread on the following:
Model year
Which fuel you were using
Mileage in state of tune
Dyno'd hp & torque
Approx engine temp.
Throttle position & gear at failure
If you had any relevant mods in addition to the basic pole options please add them as you comment on the additional points.
We have a good discussion thread on this subject running here http://www.meganesport.net/community/showthread.php?54401-Big-Stage-2-Tuning-Problem so please use this thread to collect the facts only.
Many thanks! :detective:
Ill start the ball rolling
Year-2007 (57plate)
Fuel-v-power
Mileage of car was 31,000mls and was stage 2 for around 2000mls
Dyno figures- 276bhp and 325lbft
Engine temp-....cold
Throttle position- 3/4 throttle
Gear- 2nd gear
Other mods- itg panel filter, forge silicone hoses, forge dump valve (blue spring), k-tec 3" cat back exhaust, forge actuator (yellow spring), forge blanking plate.
Engine cut back, lack of power and throttle, couple of seconds later regained power followed by a loud bang!
Piston, rod in cylinder 1 destroyed and hole in block.
225 F1 (phase 2)
Built: june 2006 on 06 plate
Fuel: shell v power at the time but used tesco 99 mainly
Mileage 42,000 (was on stage 2 for 4 months & 4,000 miles)
Dyno: 275bhp & 325ft ibs torque
Engine temp: Full temp
Throttle: foot to the floor
Gear: 2nd
History: Full Renault service history & was serviced just before stage 2
Mods: forge fmic, forge hoses, forge dump valve, forge blanking plate, stage 2 rs tuning map.
Damage: hole in block... had loss of power at 3k to 4k rpm then a big bang, heard bits of engine flying about & lots of smoke out the back :(
Paul
I'd be more interested in how many are actually happily running around in various states of tune.
E.g. i'm about to fit a FMIC then in march (warranty over) should i also go stage 1??
Model year: 2007 R26
Which fuel you were using: Tesco momentum
Mileage in state of tune: 12,000 miles
Dyno'd hp & torque: 275 bhp 340 ibs torque
Mods : Forge Fmic Milltek decat, milltek cat back, Rs tuning stage 2
History: Full renault service history, oil change 2000 miles before engine failure.
Damage: Knock from engine, 4 bent conrods, Chunk out of cylinder block
1 - 12 of 12 Posts
