1 - 4 of 4 Posts
The motor is making all the right noises and the front/lights still squirt. However there is nothing coming out the rear washer? I've cleaned it and it's not clogged etc.
Any idea what it could be?
Take rear nozzle off - work washer, does it come out? if so your nozzle is fubbered/needs unblocking.
If water is not coming out of pipe where is it coming from, under front of car? if so pipe has popped off motor, split where water is coming out. Or if all intact and no pipework issue then itl be the motor, or there is a bung in washer bottle going to pump and the bung has a gauze actign as a filter and can block up with slime
Thread resurrection - but just in case someone else has this problem.
Behind the C pillar on the drivers' side there is a green connector for the tubing. This has a tiny, pin-sized hole in it, which was blocked. I drilled it out with a very small drill (1mm?), and now all is good.
Just be careful not to pull off the rear alarm sensor when removing the c-pllar trim.
1 - 4 of 4 Posts
