1 - 2 of 2 Posts
Hi,
I am about to install a boost gauge but I could not pass the vacuum pipe of the boost gauge through the firewall. My vehicle is LH drive one and under the steering wheel on the body there is a cable loom passing through the firewall with a rubber isolator around but I could not manage to route the pipe through this rubber isolatorCould anyone help with some pictures?
if you remove the glove box ( 5 star screws ) there is a big black gromet going throught the bulk head, pull that back and open it a bit and just feed the pipe through and if the bonnet is open you should see it appera down the right hand side of the air box.
1 - 2 of 2 Posts
