This kit will replace your standard interior yellow-ish bulbs with a white xenon hid look or a choice of other colours available below.
The led's fit into the door footwell lights and the roof mounted interior lights.
Four door and two door kits available.
The bulbs used are wide angled super high power LED's so you get a glow rather than a spot.
Each bulb has 6 high power wide angled led's in each unit!!!!
They replace the small wedge type bulb.
Much Brighter then the normal LED Versions.
12v 20-25ma.
The Leds are Super Bright.
Low Power consumption.
Up to 100,000 Hours Life.
Easy Installation - Remove the old bulb and replace with this one - Simple and very effective.
These Bulbs are the same size as your standard Glass type bulb.
The 2 door kit has 8 LED bulbs in total
The 4 door kit has 10 LED bulbs in total
You even get free postage on this item!!
Item available here: http://shinyautos.com/shop/product_info.php/products_id/87
Our Website url is: www.shinyautos.com
Take a look at one of our past jobs:
Here are the Led's in the kit...
