1 - 18 of 18 Posts
Used my new snowfoam lance for the 1st time today. Didn't even use proper snowfoam as I haven't got any yet, but it was awesome! Left the car really clean after I'd sprayed it off!Which leads me onto my question. What's the best snowfoam to get and where can I get it?
I sell somthing called Chemical Guys Maxi Suds II it is great when used with a snow foam lance. I have also heard Auto Finesse Lather works quite good.
Read up on detailingworld. The main one used is 'magifoam' i use it too, good stuff but u have to let it soak for a while to do its job, i use it to loosen main dirty off, hose down then wash properly with a mitt
You get 500ml and its very concentrated. I normally use about 2cm into the lance filled up with water, all depends on how dirty the car is, sometimes I put more in to get a thicker foam.
Hope that helps
I put a decent inch of foaming agent in and fill with warm to the top, does the trick.
But now I've ordered some products off stiggy I'm going to drop a little bit( a really tiny bit) of degreaser to fully remove the **** that caked On over the last month or so.
Nice one if you do I could pop it round tomorrow if you like. I will be driving past York around lunchtime.
That'd be fantastic mate if you can. It's the address I put on the order at Clifton moor. I'll pm you my mobile no. in case you get lost.
Thanks a lot!
1 - 18 of 18 Posts
