1 - 18 of 18 Posts
Fancy posting one?
phil
I wouldn't mind it before then as i have a badly damaged one
is it in good nick? ie no scuffs or dents?
phil
Davelee225 said:
you can have the best one out the three. No scuffs.
Do they have the tyres mounted? or are they off the wheel?
i presume they are off for the tyre sensors to be removed
I dont need the tyre as i'm running 235's
phil
Phil do you have 235's on the front are they ok? Had to get 2 new yesterday so went for 235 Vredestein Ultracs and put them on the back and put my Conti's from the back on the front to use up but then i will match them up with the Ultracs but then i started worrying that they will rub on the front strut .... Standard rims too on full fat ..
No problems at all mate, no rubbing and you can hardly see the difference in size
but an extra 10mm on each corner for grip can't be bad!
Site Admin
phil
The tyres are already mounted mate.
Two down, one to go!
I want the best one aswell! :wink:
Davelee225 said:
One to go then !!!
have you got one left? can it be posted to kent & how much?
Del
1 - 18 of 18 Posts
