1 - 4 of 4 Posts
I want the Meganes suspension checked out, it's four years old and 40k without anything being replace on the front end. So one can assume bottom arms, drop links, track rod end and the like are on their last legs.
Any recommendations in the Chelmsford, Essex and Hertfordshire area?
Thanks a lot.
Can't recommend anyone but it will generally last longer than that unless its had an usually hard life. All the kit for a front end refresh is near enough £1k, all the ones i've done though are early models. Rear wishbone bushes seem to be the first to fail.
I had some play in the rear bushes hen I changed the front brakes a few thousand miles bk
Excessive though, they are meant to have a degree of flex in them otherwise they wouldn't be there. They will knock under cornering when totally shot. The vibratechnics rear bushes are a shout if you have deep pockets and feel the need for them.
1 - 4 of 4 Posts
