1 - 6 of 6 Posts
my washer jets are not functioning as they normally do. the water used to shoot to the top of the windscreen but now it barely makes halfway.
any ideas on what my problem could be ??
cheers fellas
Probably a blockage due to the weather we've been having this winter....
Do you get decent jets or is it a feeble splatter? Is it one jet that's feeble and the other still decent? Could do with having a bit more detail!
I found that the tubing had got traped where the bonnet hinge is on mine....
Check for any kinks in the pipe, like said bonnet hinge is worth a check. If not pull them off the jet itself and work the washer so how it flows out there, if good, its your washer jets, if still poor you probaly have gunk in the washer bottle and filter is blocked
1 - 6 of 6 Posts
