1 - 20 of 63 Posts
· Registered
Hi all,
Just had a good look round the car after getting over the original excitement of getting it, and found a storage area on the right hand side of the boot....it has a lttle clipped flap on it.
Under the flap there is a little storage recess and what looks like a radio DIN blanking plate.......
What's this location used for??? Should there be something in there??
Ta,
/G
· Registered
Ooooo....I have an amp!!!!!
Is there anything under there I can play with, or isn't it worth the hassle dismantling the boot???
One question then, If I change my headunit some time, is it a direct replacement using the amp or do I have to 'rewire'??????? I realise I may need a loom adaptor from, say, autoleads.
/G
· Site Admin
Friad not mate. I have exactly the same unit. If you take it out and have a look at the back, there's only 6 wires. There are no speaker cables in the back. The cabasse unit is not a stereo was we know it. The unit runs of a canbus lead straight to the ECU. The only way to change the headunit would be to re wire the car !!!!
· Registered
They don't make that well know, do they!!!!
Surely they expect people some time in the car's life to change the headunit, they should make that quite clear!!!
I was planning to fit a car kit and then use one of those ISO mute cable to channel the sound through the speakers......shafted would be a good word!!! :(
· Site Admin
Yes Mate, Renault have pulled a fast one. So if your stereo goes wrong after warranty, you have to buy another one from them !!!!
You can have a sound system in your car, a bit like my install although you will have to keep the original headunit.
You'll find majority of the Renault sales team, and even the service / parts department don't really know about it either !!!!! Well they don't at the Renault dealerships near me.
As for the hands free kit mate, i think your pretty much buggered there. Although it might be worth just looking into.
· Registered
What about the AUX that I have seen in the menu listings???? What's this all about??? Anyone connected to it and use it??
I'm getting desperate!!!!!
Anyone had it out with Renault yet on this issue????
· Registered
Discussion Starter · #15 ·
It would seem to me that if the Cabasse unit is spec'ed, that there should be some sort of warning issued that if you wish to have after-market radio or intergrated handsfree installed either don't have it or spec the handsfree pre-wiring!!!!!
Ooooooooooooooo!!!!!!!!!!!!!!!!!!!!! :x
1 - 20 of 63 Posts
