1 - 3 of 3 Posts
if i want to change the wheels on my r26 can u put the sensors in other wheels and will they work the same or is it alot of messing around and also what is the advantage of changing the brake hoses to braided
As I understand the sensors are colour coded and shouldn't be swapped about but the system can be programmed I think..
Braided hoses give a better and more consistent feel to the brakes and a harder pedal too...more noticeable on older cars.
As I understand it, as long as you keep note of which colour sensor goes on each corner of the car, and you're careful not to damage them during removal and refitting to the second set of wheels, it shouldn't be a problem.
1 - 3 of 3 Posts
