??? how do i bleed the coolant system ???
6K views 4 replies 3 participants last post by  Gazeratti
#1 ·
i will be fitting a new rad tomorrow due to a leak just need to know is there a certain way to bleed the coolant system as i cannot see any bleed nipples or do you just refill via the header tank
any help much appreciated
#2 ·
Bleed bolt on the thermostat housing (its the one that sticks out) and another one on the top heater matrix hose. Open both of these and fill via the header tank until you get a continouns stream out of both then close the circuit and run the car up to temperature letting the fan kick in and out 3 times. Then fill the header tank to the max mark.
Officially thats sufficient to degas the system but you'll find that the level in the header tank will drop the next couple of times you drive the car as all the air will work its way out.
