Stereo turning itself up and down?
6.6K views 15 replies 8 participants last post by  bud
#1 ·
Had the car 5 days now and love it to bit but i think i have an issue with the stereo.
It seems to be turning it self up and down on its own when im driving?
The actual volume number on my screen shows the same e.g 20 but the sound will shoot up a little and then down? Seems to happen alot when im accelerating or braking?
It doesnt shoot up much but enough to annoy me!
Had a search on the forum and looks like im the first person to have this issue or im just being picky and theres nothing wrong with it??
Thoughts?
#13 · (Edited)
Display the settings menu by pressing 9. Select “Audio settings”.
To move:
– by turning 5 to move vertically;
– by pressing 4 to move horizontally (movement A);
– by pressing 5 to move horizontally to the right only.
Note: the system exits the settings mode automatically without the need for any action on the part of the user.
You can also exit the settings mode by pressing 9. To return to the settings mode, press and hold 4.
Note: setting 0 means the function is deactivated.
Access the “Other audio settings” menu and check “Adaptation volume km/h”.
Adjust the volume/speed ratio by turning 5.
#14 ·
I guess it depends on the radio, I have the 'uprated' Arkamys 3D with the SatNav screen and mine does it too. To turn it off you need to go in to settings then Radio settings and there is a Speed dependant volume sensitivity (can't recall the actual name, but something like that) .... and there are about 3 to 5 levels of sensitivity and an off.
I have the same setup so thats handy. Will post back once done
